Home › Forums › Products › Stompboxes › MIDI PC + Clock not working on H9 Max + H9 Core + Dimehead › Reply To: MIDI PC + Clock not working on H9 Max + H9 Core + Dimehead
November 30, 2025 at 4:00 pm
#193500
thanks for the answer.
The MIDI channel is the same for all the devices. When I just switch the MIDI OUTPUT to “THRU”, the presets are changing on all devices and this makes me think the wiring and the configuration are correct.
It is like the message sent as THRU+C is just the clock info and not the PC forwarded from the pedalboard.
