Home Forums Products Stompboxes H90 Kill Dry questions Reply To: H90 Kill Dry questions
#193570
    I’ve moved your question to a dedicated topic so it’s easier for users to find this information.
    The Global controls accept CC messages, but there is no command for Kill Dry on/off.
    Kill Dry has a global setting for Presets or Program. If you set Global Kill Dry to On, then your Progam will always have kill dry on if the parameter is set to Global. I’ve attached a screenshot that shows the Program kill dry set to global.
    You can adjust the global Kill Dry setting by going to System > Global on the pedal: https://cdn.eventideaudio.com/manuals/h90/1.11.4/content/system-menu/global.html
    Let me know if that clears it up for you.
