Home › Forums › Products › Plug-Ins › H3000 plugin: getting swirling Ministry-style vocals (Logic / MainStage) › Reply To: H3000 plugin: getting swirling Ministry-style vocals (Logic / MainStage)
December 9, 2025 at 4:18 pm
#193618
If you open the preset browser in the plug-in, you can find categories by effect type. I’d suggest checking out “Filter Delays” or “Panning” as a starting point.
Nothing particular about your DAW that will make a difference when using the plug-in. You can experiment with using the effect as an insert or send/return effect depending on how you want to mix things.
