Home Forums Products Stompboxes H90 and IRX – Channel MIDI change Reply To: H90 and IRX – Channel MIDI change
#193717
    Yes, you just need to set the output mode to Transmit and whenever you load a Program on the H90 it will send a PC message: https://cdn.eventideaudio.com/manuals/h90/1.11.4/content/system-menu/midi.html
    You may also want to turn the PC offset setting to 1.
    You cannot connect that MIDI controller to the H90 wirelessly, but it should work with a TRS to DIN adapter such as this: https://store.eventideaudio.com/collections/cables/products/trs-to-midi-adapter-cable
    Let me know if you have any other questions.
