Home Forums Products Stompboxes H90 and IRX – Channel MIDI change Reply To: H90 and IRX – Channel MIDI change
#193777
VictorHA
    Hello.
    After making the configurations I indicated, how can I map the PC commands on the H90 to their corresponding inputs on the IRX? Would it be through the control assignments in the H90 control app?
    For example, I have a preset with chorus and delay, and I want it to correspond to a preset on channel 1 of the IRX when activated.
    On the other hand, in another preset with delay and reverb, I want it to correspond to a preset on channel 2 of the IRX when activated.
    Regarding the Mvave, I was referring to the standard P2 input, which in the photo above is indicated with the term “pedal”. I was wondering if I can use it with a TRS cable (using a P10/P2 adapter, of course) and connect it to the H90’s expression input to obtain an external auxiliary switch, or even with a TRS MIDI cable as you suggested.
