Home Forums Products Stompboxes H90 update issues Reply To: H90 update issues
#193937
Jethro Toe
    Hello! It’s not working. I did this all steps:
    Connect your H90 to your computer via USB
    Boot the pedal into Recovery Mode: https://cdn.eventideaudio.com/manuals/h90/1.10.7/content/appendix/startup.html#recovery-mode
    You should see a drive on your desktop labeled “H90 Pedal”
    Delete the contents of that drive
    Empty your computer’s trashcan
    Download the .os file from the following link, then drag it to the “H90 Pedal” drive: https://downloads.eventide.com/audio/firmware/h90/h90-1.12.5.os
    On your Mac, go to /Library/Eventide/H90 Control/FirmwareIf you cannot find the Library/Eventide folder, follow these instructions https://support.native-instruments.com/hc/en-us/articles/360020012418-Accessing-the-Hidden-User-Library-macOS
    Manually copy the latest .pak, and .bam files to the “H90 Pedal” drive
    Once the .os, .pak, and .bam files are all on “H90 Pedal”, eject the drive and restart the H90
    But pedal load without update after I did this steps. I tried in MacOs Tahoe 26.2 and Windows 11.
    Recovery mode running with no problem. I delete from H90 drive all files and then copied latest .pak, and .bam. But when I restart pedal it just loads. When I open H90 Control it shows that my pedal update version is v1.12.5 but when I connect my pedal to H90 Control the system setting shows that the currently version of software is 1.11.4.24. And new algorithms not works. I can select these algorithms, but the signal remains dry, without processing by the algorithm.
