Home Forums Products Stompboxes H90 Control – changing route to DUAL deletes my user presets Reply To: H90 Control – changing route to DUAL deletes my user presets
#194082
wedelich
    You’ve lost nothing by switching to Dual Mode, all the Programs and Presets from your lists are still there. If you want to convert a List to Dual Mode, you should do the following:
    1. Use H90 Control to export your List to your computer.
    2. Switch to Dual Routing on the H90 Pedal (be careful to follow instructions and make sure your cables are in routed correctly to prevent feedback loops)
    3. Use H90 Control to re-import your List
    4. H90 Control will prompt you to agree to convert the Programs to Dual Routing, click OK
    All your programs should now exist in Dual Routing Path A, feel free to edit as you like, you won’t mess up your original Insert Routing Mode counterpart.
