Home Forums Products Stompboxes Granular Thoughts Reply To: Granular Thoughts
#194128
    Thanks for the feedback! Glad to hear you are enjoying the new algorithms.
    In GrainMod, you can modulate the trigger rate. This is the Trig Mod Rate parameter.
    In Glitch, if Flux is set to Burst then it will modulate the Burst Rate. The Glitches will always be very short grains, this was an intentional decision because once the grains are longer it doesn’t sound like glitches any more. If you still want some of the Glitch effects I’d suggest pairing it with GrainMod.
    Interesting idea about pre/post reverb. The beauty of the H90 is you can combine the granular algorithms with any effect you like pre/post/parallel. So you can try this yourself with any reverb of your choosing.
