Home Forums Products Stompboxes Problem with dual routing Reply To: Problem with dual routing
#194135
albertoplen
    Thanks for replying.
    I don’t know what the problem was because I think I did the same thing as the previous 10 times, but now it works fine!
    The only thing is, I had to change the bypass type to Relay, which I’m not entirely sure what it does, but otherwise, the amp didnt sound work with the H90 deactivated, and with the”relay” mode, I have the amp, the preset in pre, and the preset in post. So, perfect!
    Cheers
