Home Forums Products Stompboxes Switch presets via MIDI ? Reply To: Switch presets via MIDI ?
#194190
    What have you tried so far?
    You must first select your Playlist and then you can send PC messages from 0-99 to load the various Programs on that list.
    As long as the H90 is set to the correct channel and you have connected the Fractal to the MIDI input, it will change Programs when it receives a PC message.
    I’m not familiar with Scenes on the AM4 so I can’t offer any suggestions there. Have you used this device to send PC messages before?
