Home Forums Products Stompboxes H90 Looper Reply To: H90 Looper
#194213
    … HERE’S THE PROBLEM: I set a different switch on MC6 to send CC# 32 to H90; when I hit it during playback, NOTHING HAPPENS.  H90 continues to play.  I tried re-assigning the CC# to a diff value (in case H90 doesn’t like the number 32?!?), same outcome: Stop doesn’t work from MC6 but play and record do?!?!
    I tried to reproduce this, same setup.  Stop & (long press) Erase both work as expected, even mapped to CC#32 (or any other CC# I tried).  I’m thinking it has to be on the MC side of this equation.
    Anything jump out as different in the Action / Message types, comparing Rec / Play to Stop?  Maybe bring up the MIDI Monitor to see if anything looks funky on that end.
