Home Forums Products Stompboxes H90 Bluetooth permanent on! Reply To: H90 Bluetooth permanent on!
#194277
    The H90 should remember the Bluetooth settings after a reboot.
    If you turn Bluetooth on, and then power cycle the pedal, does Bluetooth always turn off? If that is the case can you please email support@eventideaudio.com with a video that shows this? It would also be helpful to send in your pedal logs, see #1 here: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/h90-control/edit.html#parameters-edit-menu
