Home › Forums › Products › Stompboxes › H90 Bluetooth permanent on! › Reply To: H90 Bluetooth permanent on!
January 16, 2026 at 3:09 am
#194278
Now I found out, that the H90 remembers its Bluetooth state, if my Mac is turned on before! the H90.
If there is the corresponding Bluetooth signal before I turn the H90 on, the H90 seems to turn on Bluetooth as it is the last state.
But if I turn on the H90 first – which is the normal procedure – then the H90 does not turn Bluetooth on.
I did send the pedal log via mail.
Thank you for your help
