Home › Forums › Products › Stompboxes › Permanent Tap switch on H90 itself… › Reply To: Permanent Tap switch on H90 itself…
#194391
joecozzi
    Yes. In PERFORM mode, press the P LED button until you see the “TAP:120 BPM” option on the display. If you save the Program having made this assignment you can use P footswitch to control tap tempo. When Tempo Sync is ON, the flashing light will be a BPM indicator. When Tempo Sync is OFF, it’s best to press the LED button (A or B) that corresponds to the position of the time-based effect you want to control until you see “TAP” appear on the display. This will allow you to set the time in milliseconds. You can find a clear explanation of tempo in this video: https://youtu.be/tfd3wQHzxcA?si=LXGNY-avXhj0OnuW
