Home › Forums › Products › Stompboxes › H90 Force Mono vs. “True” mono? › Reply To: H90 Force Mono vs. “True” mono?
January 27, 2026 at 5:02 pm
#194398
Force mono does sum because we preserve the stereo input (assuming both inputs 1 & 2 are connected). The signal is processed in stereo, and the output is summed to mono at a point determined by the current Program routing. The algorithms handle the summing at the appropriate point for the given routing. Our algs are designed to handle Stereo In -> Mono Out, so it’s a bit more elegant than a simple sum in most cases.
