Home › Forums › Products › Stompboxes › H 90 effect suggestion › Reply To: H 90 effect suggestion
#194404
    … To my ears, the effected sound is a more brittle/ice pick than I’d have preferred, but that is kind of the nature of the effect, I suppose…
    You might want to try Polyphony as an alternative.  Map the Shift intervals manually to expression, between unison & an octave or two up.  The Auto EQ parameter can help smooth out the top end.
    In fact, ‘though the ‘recommended’ setting is at 10, sometimes I’ll map a range of Auto EQ alongside the pitch shifts.  Another thing to try is the Inst Type toggle.  Again, the recommended value for large pitch shifts would be Pitched.  But I often prefer the results that a Percussive setting brings, especially with an instrument with a hard attack.
