Home Forums Products Stompboxes H90 Mono Sum Routing Question Reply To: H90 Mono Sum Routing Question
#194526
    If you are using a stereo insert in the H90’s signal path, that insert will always be processed in stereo.
    At the end of the signal path, your output will remain in stereo if outputs 1-2 are connected, or be summed to mono if only output 1 is connected (with the exception of the force mono parameter).
    Let me know if that answers your question.
