Home Forums Products Stompboxes H90 Wet/Dry system not working with a second insert. Reply To: H90 Wet/Dry system not working with a second insert.
#194547
joecozzi
    Hi Kevin,
    A simple wet dry system works fine but when I try to use another insert to add external effect, they do not sent to the wet amp….I’m using INSERT mode, Kill Dry ON. All works fine but then I connect an external effect to the H90 (tried all input and output combos) and I can’t get the external effect to send to the wet amp. Any know how to make this work? Thanks, Kevin
    Can you clarify a few things?
    1. Where do you have your insert 1 and insert 2 points in reference to Preset A and Preset B?
    2. Do you have insert 1 mix parameter set to 0% percent?
    3. You say you are running the effects in Kill Dry. Are you running Preset A and Preset B in series or parallel?
    4. Is the effect on Insert 2 also set to Kill Dry?
    If you run too many effects in series on your wet path and they are all operating in Kill Dry, you run the risk of not feeding enough dry signal to create wet signal. This doesn’t happen when the wet path has all the effects operating in a parallel routing. Perhaps you get some clues watching this video we did on W/D setups: https://youtu.be/0G_WtfUatSc?t=786&si=IELyChc9xWPml_BT
