Home Forums Products Stompboxes swell or violoning effect with the H90 Reply To: swell or violoning effect with the H90
#194551
    Parallel Swells is not a factory preset.
    If you are trying to import a preset file, see #12 here: https://cdn.eventideaudio.com/manuals/h90/1.12.5/content/h90-control/edit.html#parameters-edit-menu
    Otherwise, you can manually copy the parameters in the image he shared in the thread above. It’s basically setting everything to 0, set the Chop parameter to one of the Swell options, and adjust the Rise time your liking.
