Home › Forums › Products › Stompboxes › H90 Mono Sum Routing Question › Reply To: H90 Mono Sum Routing Question
If I can jump in with a related question: I’m new to routing and for the life of me I’m not sure what I’m doing wrong.
I have a Tascam Model 16, which has one FX out and two Aux outs (all summed to mono afaik), as well as stereo control room outs and sub outs. Currently I have the control room outs coming lined to inputs 1+2, going to outputs 1+2 routed to channels 11/12, which is how I was told was a good solution. The other was to use the Aux outs in a similar fashion, only I’d get a summed mono mix converted to stereo, but I’d be able to split the effects in the mix using the per-channel Aux knobs. However, neither seems to really work. I’m definitely getting sound out of it, but I can barely hear it in my headphones, even at max output. I feel like there’s some switch I need to be applying, but I have no idea at this point point. Any advice is greatly appreciated.
