Home Forums Products Stompboxes H90 Not Connecting to Software Reply To: H90 Not Connecting to Software
#194739
    Below are some general troubleshooting steps you can try:
    • Make sure no other programs, such as a DAW (even if it is closed), are trying to connect to the H90.
    • Make sure you are not using a USB hub.
    • Make sure you are using the Eventide power supply.
    • Make sure there are no other USB or MIDI devices attached to your computer.
    • Try a different USB cable
    • Try a different USB port.
    • Make sure no other programs are running.
    • Make sure antivirus or firewall programs are not interfering with the connection.
    • Make sure you are using the latest version of H90 Control.
    • Restart your computer.
    • Try a different computer.
