Home Forums Products Stompboxes [timefactor] Request for disabling knob catchup and speed limits in looper mode Reply To: [timefactor] Request for disabling knob catchup and speed limits in looper mode
#194911
    Thanks for your post. You may be interested in the looper on the H90 since it has been updated to include all of these improvements.
    1. Catchup is not needed on the H90.
    2. The varispeed resolution can be set before recording a loop and will autoplay back with that setting remaining.
    3. Record Speed and Play Speed are now independent parameters and you can access the full range before recording a loop.
    We are unable to implement these updates for the TimeFactor, so the H90 would be your best option if you need these features. Plus, you get an additional algorithm to put before or after the looper which really opens up the possibilities. Or, you could use 2 loopers at once.
