Home › Forums › Products › Stompboxes › Process To Set Uniform Volume of H90 Programs In Lists? › Reply To: Process To Set Uniform Volume of H90 Programs In Lists?
#195200
apalazzolo
    Thank you.  I appreciate your thoughts and agree with many of them.   I really do.  But …
    I’d like to improve is my ability to level-shift programs across my own lists, even if it’s for myself with my same guitar and board.  After creating a dozen or two programs with my own gear, I have to circle back and level shift them for consistency for my own use.  Doing this by ear can be difficult, especially if my perception of volume shifts by the time I get to the end of the list.   So I skip around the list, but boy that takes time.
    Further, program volume in Eventide’s lists are almost always consistent when I play their lists.  So even with all the variability that you correctly note, someone must know something about this. No?
    I actually do like your clipping idea:  1. deduce how much added gain will barely induce clipping in a benchmark H90 program; 2 apply that amount of gain to new programs; and 3. adjust new program level until gain is barely induced.
    Howsebout this:  1. select an Eventide program that seem “right” 2. play a sustained note from my digital organ through this program; 3. measure the AC voltage at the H90-OUT with a voltmeter; 3. play the same organ note through my programs and level-shift them all to the same measured voltage.    I might try this.
