Home Forums Products Stompboxes Slow Gear on H90 ? Reply To: Slow Gear on H90 ?
#195304
thossounds
    Hi Tony,
    Thanks so much for all this! Apologies for taking so long to check it out. The UltraSwell option is definitely in the ballpark for what I’m looking for but seems to have a few quirks I’m wondering if there’s a way to lessen. On your Bowed-CELLOs program.. I think the settings I like best are the ones with no hot switch on, so: Length: 60, Rise: 16, Spread -25. But.. I notice with the other settings, like hot switch 2, the first note played has a longer swell (great!), but if it’s still ringing on the instrument and a second note is played there’s a noticeable “tap” or altered attack of the new note. I’m used to the Boss SG where any additional notes played just come through normally.  I’ll play around with the settings more and see if I can find what I’m looking for.
    Also.. even with just one note played, sometimes it seems like there’s a “gate” cutting off the tail of the note before it fades out naturally. Any idea what parameter is causing that?
    In my own tinkering, I also got close with the Tremolopan algorithm. It seems more natural/open on any additional notes played, but still has the cut off gating effect and a slower swell time than I think I want.  Attaching in case you’re curious.
    Thanks again! Greatly appreciate the info!
    Tom
