Home › Forums › Products › Stompboxes › H90 tail on by default on factory Presets › Reply To: H90 tail on by default on factory Presets
May 12, 2026 at 7:58 am
#195432
The Program Spillover feature will only work when you are loading new Programs in Select or Perform mode. When you are previewing Programs or Presets from those edit menus, there will be no spillover.
There is no global bypass tails setting, that needs to be enable for each Program/Preset.
