Home › Forums › Products › Stompboxes › alternative tunings possible with H9? › Reply To: alternative tunings possible with H9?
Not in front of my gear, so forgive any errors. Many of the Pitch algorithms will get you there, with varying degrees of tracking, and some coloration added to your base tone. First, the things that will generally apply to most of the Pitch selections: * MIX – 100% wet. You don’t want to hear your dry tone folded in. * Pitch Mix – start with CCW for Pitch A or CW for Pitch B (unless you prefer the ‘doubled up’ tone at center). * Pitch A / Pitch B – often set to -m2 for Eb, with an exception* below. If you are only dialed in Pitch Mix toward one Pitch, the other Pitch value won’t matter. * Delay A / Delay B / Feedback A / Feedback B – Normally, all set to 0. .
HI Guys, unfortunatly, I still hear bleed from my guitar … in A440.
what am I doing wrong??
Carlos
