Home › Forums › Products › Stompboxes › How to import H9 presets to H90 › Reply To: How to import H9 presets to H90
Sorry, but the plug-in presets are not compatible to import into H90 Control. You may find some of the same presets in the plug-in and on the pedal, but otherwise you’ll need to recreate them by matching the parameters.
When you use H9 Control in demo mode, you can still export Presets and Preset lists, but you would have had to first saved them to your computer. If you never saved those Presets to your computer, then there is nothing to export.
If you share the exact error message you are seeing when you try to import a Preset, that would be helpful.
It’s also worth noting that the H90 comes with all of the H9 Max factory presets built in. Importing your custom H9 Max presets is fully supported, you just need to export from H9 Control and then import using H90 Control.
