Home › Forums › Products › Stompboxes › Summing stereo inserts to mono beforehand › Reply To: Summing stereo inserts to mono beforehand
when using the two Tonex Ones as mono inserts, are these also in series entering the h90?
If you position the inserts at the very beginning of your chain in the same position, Insert 1 will always come before insert 2 in a series configuration.
I mean, if I set the Mix of Insert2 to 100%, is he then fully overriding Insert1 because Insert2 is later in the chain then Insert1? Or am I missing something here? Because if so, this would be exactly what I need!
When Insert 1 and Insert 2 are in the same position, the H90 automatically routes Insert 1 into Insert 2 as if they were to consecutive pedals in a serial chain.
