Home Forums Products Stompboxes H9 gen2 feature request: Ability to control pre loop vol when H9 effect is post Reply To: H9 gen2 feature request: Ability to control pre loop vol when H9 effect is post
#196084
    When using Pre/Post routing, the input and output gains are applied to whichever path is active. For example, of the Post path is active, the Pre path will pass through unprocessed.
    What you are requesting would be a significant change in the pedal architecture, so I would suggest another work around for your use case, like using a volume pedal before the Pre path.
