Home › Forums › Products › Stompboxes › H9 Gen2 – Unable to configure dual external footswitch via CTRL input › Reply To: H9 Gen2 – Unable to configure dual external footswitch via CTRL input
July 28, 2026 at 9:34 am
#196478
The easiest way to make sure your connected footswitch is working correctly would be to use the “Learn” function (after calibrating the footswitch).
- Go to Perform Mode
- Press and hold the left or right LED to enter the mapping menu
- Turn quick knob 2 until you see “Learn” for the control source
- Press any switch on your external controller
- You should see it automatically map to that switch
Let me know what happens.
It would also be helpful to know when you are calibrating the 2 button switch, which of the 3 bubbles are lighting up when you press either footswitch?
