Home Forums Products Stompboxes Mix in Instant Flanger preset for H9 Gen2 Reply To: Mix in Instant Flanger preset for H9 Gen2
#196956
rantanplan747
    Taken from the manual:
    “Instant Flanger – Depth: Controls the mix of wet and dry signals. At 0% the output is solely the wet signal. At 100% the output is the sum of the wet and dry signals. At −100% the output is the sum of the wet signal and the inverted dry signal.”
    “Mix” is simply called “Depth” in this algorithm. Does that help?
