Home › Forums › Products › Stompboxes › H90 with MOTU Interface – TRS to TS Cabling Advice Needed › Reply To: H90 with MOTU Interface – TRS to TS Cabling Advice Needed
September 8, 2026 at 1:57 pm
#200383
Hi zakiddine,
I’ve moved this post to the stompbox forum for you. It sounds like you have a pretty good idea of how this can all be hooked up.
As others have mentioned, you will most likely be fine with TS cabling without running into any issues.
I’d suggest trying out the audio interface to H90 connection using TS cables and see if you run into any issues before trying anything else.
