Home › Forums › Products › Stompboxes › Eventide H90 MIDI PC Change and Bypass at the same time › Reply To: Eventide H90 MIDI PC Change and Bypass at the same time
I tried the 1.13.2 beta firmware. The ON/OFF issue has definitely improved, so thank you for the fix.
However, when I switch presets slightly faster using my MIDI switcher, the ON/OFF issue can still occur.
On stage, I often need to switch at around this speed, so I would feel more comfortable if the H90 could reliably handle slightly faster switching.
Interestingly, I never experienced this issue at all with the H9.
For reference, I’m using a MusicomLAB EFX MK-V as the MIDI switcher, connected directly to the H90. The MIDI cable is less than 30 cm long.
Thank you again for your help. I hope this can be improved further.
