Home › Forums › Products › Stompboxes › Dedicated Freeze Algorithm › Reply To: Dedicated Freeze Algorithm
#203474
    … Until then I’m rocking with the H9 for the polyphonic pitch shifting, and using either a superego plus or an hx stomp for freezing capabilities. Would just be so great to have the pitch shifting and freeze functions both on the H90.
    Going from the H90 to an H9 Gen 2, it does force a different approach of sorts.  A leaner ‘economy’ to programming, that’s not necessarily a bad thing.  It’s a godsend to now have the interchangeability between both devices.
    Having both, you might consider checking out the Gen 2 as an insert into the H90.  The symbiosis of both devices leads to some incredible possibilities, with all those variable routings of three distinct presets.
