Home › Forums › Products › Stompboxes › Dedicated Freeze Algorithm › Reply To: Dedicated Freeze Algorithm
#203479
    Mr. Lee, you need to deduct points for how I parsed the PEDALS description in the Program Notes.  Please cover for me before your students get ahold of this:
    PEDALS
    EXP1 – Pan A & Manual Flex A (P/F1 & P/F2) + P/F1 Detune
    EXP2 – Pan B & Manual Flex B (P/F1 & P/F2) + P/F2 Detune
    For makeup credit, I’ll mention a few more potential avenues to explore:
    • FREEZE A (and/or) B will survive a Bypass, at either the Program or Preset level.  Yes, there already is dry + freeze happening, but this opens up additional options for fine-tuning the final output.
    • FREEZE A (and/or) B will also survive Hot-Switching.  By modifying all of the Shift & Flex intervals to taste (with Flex Time & Return Time dialed down to None), you end up with 8 ‘instant’ transpositions of the ongoing FREEZE.
    • One set of intervals for Program, HS1-HS2-HS3, plus an alternate FLEX configuration in each one.
