Home › Forums › Products › Stompboxes › H90 Looper Question › Reply To: H90 Looper Question
October 7, 2026 at 3:21 pm
#203747
Yes, this is possible using the H90’s insert paths.
It is similar to the setup diagram described here: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/setup/wet-dry.html
If you route the algorithms in parallel and place the insert after the looper, only the Looper will go out of output 3 and your guitar (plus another effect) will go out of output 1.
