Home › Forums › Products › Stompboxes › H90 Looper Question › Reply To: H90 Looper Question
October 9, 2026 at 6:54 am
#203872
Yes, since the H90 runs two algorithms you get a Looper + whatever additional effect you want. You can route the FX to be after the looper, or after your non-Looped guitar.
I should also note that this is all configurable per Program, so it is very easy to have 1 setup with FX after your Looper, and a different setup with FX on your non-Looped guitar. You can change between the setups by just loading a different Program.
