Home › Forums › Products › Stompboxes › H90 and Ampero Press 2. › Reply To: H90 and Ampero Press 2.
#204343
    You can map the footswitch to the Global P active/bypass parameter: https://cdn.eventideaudio.com/manuals/h90/1.12.5/content/appendix/global.html
    There is no global delay volume, since a Program may or may not have a delay effect loaded. There are a few options you can try:
    1. Map the expression pedal per Program to the delay mix parameter (not globally). Mapping parameters per Program is detailed here: https://cdn.eventideaudio.com/manuals/h90/1.12.5/content/edit-modes/parameters.html#mapping
    2. Use a global mapping for the expression pedal to the HotKnob, then you will need to map the delay mix to the HotKnob per Program. HotKnob mapping is detailed here: https://cdn.eventideaudio.com/manuals/h90/1.12.5/content/edit-modes/parameters.html#hotknob
    3. Use a global mapping for the expression pedal to a Quick Knob, then you will need to map the delay mix to the Quick Knob per Program. Quick Knob mapping is detailed here: https://cdn.eventideaudio.com/manuals/h90/1.12.5/content/play-modes/quickknob.html
    Let me know if you have any questions.
