Home › Forums › Products › Stompboxes › Panning and stereo outputs Factor pedals › Reply To: Panning and stereo outputs Factor pedals
I use a mixer. Use an Aux out to the pedal, returns to a stereo channel, or to two channels. You now have control of volume, panning, EQ, etc, of each effect. I use a little Mackie mixer and plug my pre-amp into it, then return my stereo outs to a stereo channel, and the mixer then provides you the mechanism to mix all three (dry + L, and R effect) to the extent you want. Works quite well in a live setting. I send a stereo mix to the PA, but I’ve got control of it up to that point. Among other things, I’m using the Eventide Micro Pitch, which has ping-pong style delays, and the effect is other-worldly with this set up. In a big room (and we have a big PA) it’s just awesome.
Rocky
St. Louis, MO
