Home › Forums › Products › Stompboxes › More Signal Level (and ideal routing) › Reply To: More Signal Level (and ideal routing)
#205975
tsternfeld
    Hey, I responded to your TGP post (the hazard of what order I check my morning notifications in), but this is really the better place to discuss if you want to be surrounded by Eventide experts.
    One thing that wasn’t there:
    > I was this many days old when I learned the H90 has TRS balanced outs,
    I don’t know where you learned this, but it’s incorrect.
    Your questions:
    > Can someone confirm that if the H90 has an instrument input and a line output, the expected behavior is some kind of built-in gain function to match those outputs? Like this should “just work” even when input and output are set to 0.0db?
    Yes, all the gain shifting for Inst/Line level on input and output is done in the analog system. So if your inputs are set to instrument level and your outputs are set to line level, you should see a +6dB gain with all internal levels set to 0dB.
    > Does changing from 9 to 12V increase headroom at all, or is this just purely for less current draw?
    The supply voltage is only for current limiting; there is no difference to the internal headroom.
