A question about using H90.
Home Forums Products Stompboxes A question about using H90.
Viewing 3 reply threads
    • #193422
      myoungsoo jung
        I’m controlling this product by stereo connecting it to a parallel mixer, but when I change the preset with the same switch, it is reloaded when reusing the same preset and causing a break in the middle.
        Can’t each preset be disconnected even when the trail function is turned on?
      • #193451
          Can you please be more specific with what the issue is?
          What do you mean by “change the preset with the same switch” ? Are you sending Program Change messages to the H90 with a MIDI controller?
        • #193491
          myoungsoo jung
            1. The device I’m using is music’s efx6, and h90 is connected to a parallel mixer and controlled as a midi.
            For example, if you set all the h90  1presets together on 1st to 5th in the switch and change the switch presets, the h90  1presets will be re-loaded every channel change, causing a disconnection in the middle. Can you remove the re-loading part when you bring back the same presets?
            *I’m also attaching a picture of the pedal board I’m using.
          • #193545
              Sorry, it’s still not clear to me what the issue you are having is.
              Please make a short video that demonstrates the issue and send it to support@eventideaudio.com and we can help you there.
