A quick (and probably easy) midi question.
Home Forums Products Stompboxes A quick (and probably easy) midi question.
Viewing 3 reply threads
    • #111240
      ROBLEISHMAN
        I have a dilemma, first my set up
        kieth mcmillian 12 step foot controller (for program changes and sending notes to a microkorg)
        midiout to
        timefactor (set to midi thru)
        to
        pitchfactor (set to midi thru)
        to
        microkorg
        currently this works to select for bank selects and triggering notes on the microkorg, however, Iwould like to set the tempo for both pedals and the microkorg with the timefactor. Is there a way to "piggyback tempo data" down the proverbal pipe when the timefactor is set to thru?
        is there another way to set this up using channels or something?
      • #125080
          Sorry – the TF is either XMT or THRU – it can't be both. If you want to do it this way, you could look at a MIDI Merge box from someone like MIDI Solutions.
        • #125081
          ROBLEISHMAN
            That's what I was afraid of…
          • #147364
            anybody knows if I can send tempo from my timefactor to microkorg?
