Activate next preset with one click
Home Forums Products Stompboxes Activate next preset with one click
Viewing 4 reply threads
    • #109586
      jonathanferrier
        is it possible to activate the next preset with one click, instead of the two click process (ie: 1. increment up/down; then 2. Load)?
        If not would and aux or midi switch allow a one click increment and load?
        Thank you 🙂 Jon
      • #124279
          Looks like you probably need MIDI Program Change.
        • #124280
          jonathanferrier
            do you mean the software program in the stompbox?
            thank you, jon
          • #124281
            jonathanferrier
              Could I put the factor pedal in play mode, set the load parameter to button 4 and the increment up to button 4 to engage each function with one click?
            • #135223
                Not sure what you mean by button 4.
                If you connect increment and load to the same place it may not be obvious which happens first. You'll have to try it and see.
