Active button on Aux Switch
Home Forums Products Stompboxes Active button on Aux Switch
    • #114871
        How can I setup one of the Aux switch buttons as the Active button on the pedal? There is a Bypass option but it is not acting exactly as the Active button which activates the chosen preset. Bypass first deactivates and then activates the preset chosen by switches.
      • #149826
        bohan
          You can assign your aux switch to "Left Footswitch". See attachments for more detail.
          • #149830
              How did I miss that?! Thanks.
              bohan wrote:
              You can assign your aux switch to “Left Footswitch”. See attachments for more detail.
          • #151430
            I have the OX9 and the Tesla Tap for my Eventide H9. I am having a problem with the mapping and am wondering if you can help.
            I want to set it up as follows.
            Left button on the OX9 to decreases through the presets
            Right button on the OX9 to increase through the presets
            Tesla Tap toggle the tuner on and off.
            What seems to be happening is that whatever I have mapped to the foot switch 1 (Tip) and than foot switch 3 (tip + ring) the end up controlling the same thing.
            SO if FS 1 (tip ) is set to increase through the Presets and FS 3 (tip+ring) is set to Tuner toggle both of the FS’s control the tuner toggle.
            What am I missing any advice would be greatly appreciated.
