Algorithm output level with expression pedal
Home Forums Products Stompboxes Algorithm output level with expression pedal
    • #114670
      Mattedbass
        Im sure this has been talked about but i cant find anything on it.. Im trying to control the output level on the pitchfuzz plugin with an expression pedal as when the fuss is brought in the level drops (standard with bass) and want to boost the level a little with the fuzz.. But i cant set it like i do the other parameters.. Is there a work around?
      • #148805
        bohan
          You can assign the expression pedal to control output volume on a preset by preset basis. Please see the attachment.
