algorithms working only on one of two h9
Home Forums Products Stompboxes algorithms working only on one of two h9
    • #114801
      I have two h9 cores. I’ve recently purchased two algorithms but only work on one. From account everything is ok but from page algorithms no
    • #149524
      gkellum
        roversella wrote:
        I have two h9 cores. I've recently purchased two algorithms but only work on one. From account everything is ok but from page algorithms no
        You should be able to use the Restore Purchases function under the Settings bottom bar menu in the app to fix this problem. It wil install your purchased algorithms on your other Core.
      • #149532
        Ok thanks I had missed this setting.
        Now I solved.
        thank you
