Amp channel Switching with H9
Home Forums Products Stompboxes Amp channel Switching with H9
    • #114885
      assaanar
        HI there. Can you do it where we can switch channel on the amp with H9 espression output and save it with each preset?
      • #149882
        bohan
          assaanar wrote:
          Hi there. Can you do it where we can switch channel on the amp with H9 espression output and save it with each preset?
          Hi, that expression jack is for EXP/Aux switch inputs. It cannot output signals.
        • #149957
          camn
            If your amp had MIDI control you could maybe pull it off with the MIDI XML map?
