anyone using tricerachorus pedal stereo in ?
Home Forums Products Stompboxes anyone using tricerachorus pedal stereo in ?
Viewing 3 reply threads
    • #192725
      hanscees
        I can’t get my tricarechorus pedal to work with a stereo in signal. Anybody has that working, so I know it’s even possible?
        I have the dipswitch on stereo, input cable is stereo.
        Now if I use two mono output cables one has no signal. If I use a stereo output cable also only left or right has a signal.
        Any help would be very much appreciated!
        hc
      • #192806
          Yes, a stereo input is possible. It sounds like you have tried the correct things so far.
          What exactly is the stereo input cable you are using? You need to use a TRS cable for the stereo input to work properly.
          What is the stereo source you are sending to the TriceraChorus.
          I’m not sure what you mean by “two mono cables” verses “one stereo cable” for the output. The stereo output of the TriceraChorus uses two TS 1/4 mono jacks.
          To sum up how to connect in stereo:
          • Set input dipswitch to stereo
          • Connect a TRS 1/4 stereo cable to the input. You will need to feed it a stereo signal.
          • Connect two TS 1/4 mono cables to the outputs, and connect those to your amps/monitors.
          Let me know if that helps.
        • #192842
          hanscees
            Hi dear someone,
            This works! It didn’t yesterday, but that must have been due to a faulty cable and apparently my lack of thought after trying for some time and not succeeding.
            My input are two behringer provsmini synths, but anyway it works.
            Couldnt find any conformation anywhere the tricerachorus was indeed taking stereo input. So thanks a bunch!
            greetings
            Hans-Cees
          • #192902
              Glad to hear you sorted this out!
