Auxiliary hotswitch + tap tempo?
Home Forums Products Stompboxes Auxiliary hotswitch + tap tempo?
Viewing 0 reply threads
    • #114216
      With my H9 I have both an expression pedal and a single auxiliary switch.
      The expression pedal performs as expected, and thankfully with one of the recent updates I can also unmap the settings so the expression pedal can function as a volume pedal.
      I use the right switch on the H9 to navigate through my saved presets and I can press the wheel to change direction up or down.
      The single auxiliary switch is set up to function as the hotswitch.
      However, some songs I’d like to use the tap tempo features while still being able to navigate easily through my presets. Is there a way to do this?
      I should just be able to go into a preset > click more > check a box next to “auxiliary switch controls tap tempo” (just like there is a checkbox for “EXP controls input/output volume”), but this doesn’t appear to be a feature.
      Does anybody have another solution for tap tempo, or is this something that could be added into the app?
