Basic wahwah in H90?
Home Forums Products Stompboxes Basic wahwah in H90?
    • #191603
      alpargatagazer
        I think it’s kind of a dumb question but, what config should I use to make my exp pedal a regular wahwah? Just a basic config to achieve with a regular CryBaby or whatever will do. I tried “Vintage Wah” and it didn’t do the trick.
        I know that wahs are basically filters but I haven’t use one myself and I’d like some help with it.
      • #191605
        joecozzi
          You’ll want to use the Q-Wah algorithm on the Vintage Wah preset. Map the Manual Mod parameter to the expression pedal. Make sure it goes full sweep (0-100). Bottom allows you to set the max bass frequency. Adjust Intensity and depth to taste.
          Here’s a video explaining it: https://youtu.be/ZpfqKINai4w
        • #191606
          alpargatagazer
            I got it know! Thanks a lot.
